Can You Help me...
Old Apr 29, 2009 | 09:31 AM
ranorris2's Avatar
What am I doing wrong...wiring???
I hooked up everything to my system last night, and...it only works at low volumes. I have a JL Audio 250/1v2 amp and 2 10" JL Audio W0v2's. When it is at low volumes it sounds great, but as soon as I turn it up the subs cut off. Why would it be doing this?
I thought the amp maybe going into thermal mode, but that is not the case either, the amp is working just fine. The only thing I could think of is I hooked up the speaker wire from the amp to the woofers wrong...
I took the + and - negative from one terminal on the amp and ran it to the + and - on one of the speaker terminals, then used the other + and - on the amp and ran it to the other speaker. Seemed right to me, but when I looked on JL's website it looks like they just use on of the + and - terminals on the amp and then split those wires to both speakers. I hope all of that made since...let me know if you need more information or not.
I dont know whats going on, any help is appreciated.
Old Apr 29, 2009 | 12:31 PM
ranorris2's Avatar
Anyone...
Anybody with a slash series jl audio amp hooked to two or more woofers could you show me a pic or tell me how you ran your speaker wires, so i can see if I ran my correctly???
Old Apr 29, 2009 | 05:48 PM
JJDH's Avatar
voltage dropping below 10 volts
Old Apr 29, 2009 | 08:28 PM
ranorris2's Avatar
I have a new battery and my amp and sub shouldn't be drawing that much power from the battery, should it?
Old Apr 29, 2009 | 08:35 PM
JJDH's Avatar
it can. check ur grounds.the only thing thay makes jl amps cut out is a voltage drop. prolly should do big 3 upgrade to grounds
Old Apr 29, 2009 | 08:37 PM
JJDH's Avatar
as far as speaker wiring its a mono amp it is all thge same. really i just go from one speaker to next tie together, then one wire up to amp.
Old Apr 29, 2009 | 08:40 PM
ranorris2's Avatar
what is the "big 3 upgrade", I have a 4AWG for my ground but I probably dont have it grounded in the best spot, where do you have yours grounded?
Old Apr 29, 2009 | 08:59 PM
JJDH's Avatar
do a search on forum. there is alot of info on the big 3... battery- to chassis, cab to frame ground. engine to frame ground.
under neath the truck there is a gusset or hallow rail that covers the bottom of the seatbelt bolts. in that on the far passenger side is an egg shaped hole, what i did was drilled a 1/4 in spotter hole,up through floor , then rouned out the oval hole with a unibit big enough to get a socket in, i then used jl audio master ground lug, it is basically a nickle plated bolt, that has a nut on top and bottom. doing it this way it can be bolted tightly, and also accept more than one ground. this is overkill, but it is done right, i dont have to worry bout ground being a prollem. cab floor. sand all paint to bare metal.
Old Apr 29, 2009 | 09:05 PM
ranorris2's Avatar
alright well i guess i will give the big 3 a shot. Thanks alot
Old Apr 29, 2009 | 09:10 PM
JJDH's Avatar
check voltage at amp when bass hits
Old Apr 29, 2009 | 10:09 PM
ranorris2's Avatar
alright i will do that tomorrow
Old Apr 30, 2009 | 02:40 PM
ranorris2's Avatar
Well it took me a while to figure it out but FINALLY i fixed the problem...I had the remote wire going to the front left speaker and not the actual power...im an idiot, but at least I got my bass wahoo
Old Apr 30, 2009 | 05:38 PM
04screw22s's Avatar
Just FYI.... Unless you replace your alternator the Big 3 upgrade will not give you any improvement.
Old Apr 30, 2009 | 05:46 PM
JJDH's Avatar
ok.
Old Apr 30, 2009 | 05:48 PM
MOford21's Avatar
I really doubt with 250 watts he needs to do the big 3 anyway.
