Is a ground needed for a toggle switch?
Old Mar 17, 2009 | 07:49 PM
Steeda1996's Avatar
I have had a amp and subwoofer setup in my truck for a while. I have a remote wire that I want to connect a toggle switch to. So, I can turn the amp off and still listen to my factory speakers. Main reason is when I have my kids in the truck. So, my question is; do I need to ground the switch just to turn the amp on and off by the remote wire?
Old Mar 17, 2009 | 08:37 PM
C. Whammy's Avatar
i have the same thing in my car, im pretty sure i only had to ground it b/c the switch has a light on it
Old Mar 18, 2009 | 01:30 PM
Low_e_Red's Avatar
Remote in ---> ./. ------> to Amp.
Old Mar 18, 2009 | 01:52 PM
Steeda1996's Avatar
Yeah, I want to put a toggle switch inline on the remote wire. My question is, if the toggle switch has a ground do I need to use it?
Old Mar 18, 2009 | 01:57 PM
no usually the ground is only there for the light or indicator.
some toggle switches come with only two prongs, and dont have a ground at all.
Old Mar 18, 2009 | 02:29 PM
yetti96's Avatar
If there is no LED indicator a ground would be a very bad idea. It would short out the remote power wire if grounded. Do as Low_e_Red says, the switch is just in line and disrupts the power when you see fit.
Old Mar 18, 2009 | 02:33 PM
Hespen537's Avatar
The ground is there only to operate a light. I cant recall a time where i've seen a ground without a lighted switch. You usually cant have two currents flowing through a standard toggle. Or never I should say.
Old Mar 18, 2009 | 03:25 PM
Steeda1996's Avatar
Ok, makes sense. The switch I have does have a light on it or indicator light. Thanks
Old Apr 6, 2009 | 08:14 PM
Justin_w32's Avatar
Ground is only needed if the toggle switch has a light on it.
