power wire help
Old Mar 14, 2009 | 04:05 PM
gatorbait10's Avatar
power wire help
where do i start to run 1/0 wire underneath the truck?
ive read a bunch of other threads and whatnot just kinda unclear.
i have found where the wire comes back into the cab. do i go from the battery straight under the truck, or from the battery into the firewall and then out of the cab??
Old Mar 14, 2009 | 09:05 PM
Low_e_Red's Avatar
Ok, if you are going through the grommet at the back of the cab. Take a long ziptie or something and right behind the battery there will be some plastic. Go right in between that and the cab straight down. Then just run the wire through what looks like a loop. Lastly, through the grommet. And voila.
And remember, the wire is like your manhood. If you dont wrap it up, you might end up with a 40K+ problem.... (And Ill bet money Im suspended again....)
Old Mar 15, 2009 | 01:27 AM
okay well i got frustrated and not having the right size conduit lol i just decided to run it down the drivers side inside the cab and to my surprise it fit
