Best AMP for JL Audio.
Old Mar 12, 2009 | 09:33 AM
stx2006's Avatar
What's the best amp for the sub I have? I want to get the max power out of this thing!
I have the JL Audio 8W1v2-4
http://www.crutchfield.com/p_1368W1V...-4.html?tp=111
Old Mar 12, 2009 | 09:36 AM
stx2006's Avatar
Woops I put the 8inc sub.
mine is the JL Audio 10W1v2-4
Old Mar 12, 2009 | 12:21 PM
7lug's Avatar
How much do you want to spend?
Keep in mind your impedence will be 4ohms for that single voice coil sub, so instead of getting a 1 channel (mono) sub amp (which often aren't very powerful at 4ohms), get yourself a solid 2 channel and bridge it. If you plan on adding a sub later, then start off with a 2ohm stable mono amp.
That sub is the entry level JL and will do well in the 300-400wRMS category. There are a ton of amps out there fitting in every price range. Here's just one example in the $175 range that will do rated power and is warranted through the manufacturer as it it sold through an authorized dealer and deliver a solid 400wRMS to that sub
http://www.onlinecarstereo.com/CarAu...roductID=19569
Old Mar 12, 2009 | 01:40 PM
NCSU_05_FX4's Avatar
I went with JL amps to power my JL speakers and sub. I figured sticking with a single manufacturer would keep things simple.
- NCSU
Old Mar 12, 2009 | 01:52 PM
vtelvr's Avatar
I have an old 250/1 JL amp that is pushing a single 10" W3 single voice coil. I have it in a JL sealed box and it rocks! I am thinking someone with audio experience can get more out of it, but I am happy with it. At least till I amp my door speakers! Then I will look into bumping it a bit more.
Old Mar 12, 2009 | 01:56 PM
stx2006's Avatar
Well I have a Rockford Fosgate Punch amp but I cant remember nothing about it. Which sucks. lol.
But can you bridge two diff amps together?
Old Mar 12, 2009 | 10:26 PM
JJDH's Avatar
jl amps
jl amps varie their ohm range on their own, as far as puttting an amp u think is crappy together with a top o line amp, just dont soung good, go to jls web site
Old Mar 12, 2009 | 11:19 PM
blackf150337's Avatar
since you have a jl sub, which is a SQ sub...get a high quality brand amp that has an honest power rating... you'll be glad you did in the end..
Old Mar 13, 2009 | 04:52 AM
Low_e_Red's Avatar
Honestly 150wRMS is plenty.
Old Mar 14, 2009 | 10:21 AM
BlueFordMatt's Avatar
You could start with a better sub! But if you are dead set on that sub, and it needs to be louder, you need a better box. Not a prefab, because your sub will be suffocated. a Custom box! Worry about a powerful amp after those two basics are covered
Old Mar 14, 2009 | 09:11 PM
Low_e_Red's Avatar
Theres nothing wrong with that sub. And there are many prefab companies that make fine boxes for these trucks.
Old Mar 14, 2009 | 10:10 PM
I have never heard a prefab box that hasn't killed the sound coming out of their boxes. The guy needs a custom tuned enclosure. That way if he listens to rap 35-40hz, rock, 50-55hz, or SPL 60-80hz. Prefabs are cheap boxes thrown together. Some look nice in the way they fit, but never in the way they sound!!
Old Mar 14, 2009 | 10:35 PM
mSaLL150's Avatar
Besides enclosure size, explain how you custom tune a sealed box?
Old Mar 19, 2009 | 10:24 PM
stx2006's Avatar
well I bought a box for the sub from SuperCrewSound but it doesn't fit my truck cause I didn't see that it said it only fits the 2003 2004 supercrew.. So I'm trying to send it back.
My amp may just not be set right. I didn't change any of the factory settings on it when I got it. Cause I didn't know what to put it on...
If I have a sealed box what should I have the settings on?
Does anyone know of a company that has a box that will fit under the back seat behind the driver? I dont want it to go over the hump in the middle..
Edit:
http://supercrewsound.com/commerce/p...Id=14&catId=58
Thats the box I bought. It doesn't look like that either.. Its bigger and taller then the pic shows.
Old Mar 20, 2009 | 01:40 AM
Low_e_Red's Avatar
Please explain it to me too.... Because Id love to know where I went wrong over the past 7 years and all my MECP stuff....
