Help me hook up what i have.
well long story short i picked up 2 12s that are pioneer and they are 4 ohm subs. and i have a kicker kx 600.1 and i am trying to wire themto the amp but my worst fear is blowing the amp the woofer i will be little less anoyed if i do that of course i dont want to do it to either to do so. hear are the specs of the amp
http://www.sonicelectronix.com/item_...r+KX600.1.html
i am new to installing audio so any help is apprreciated greatly.
i also just bought a pioneer DEH-P6000UB if this makes a diffrence while hooking them up
That stuff should work perfect together. Just hook both of them up to the amp to the same leads on the amp. It is designed so that it will handle two of those subs at once off the single speaker output.
600 rms / 1200 max output on the amp ..... so about 300rms / 600 max per sub
The amp is designed to run full power at 2 ohms. Those subs are 4 ohms each. But when you wire two up it actually ends up mathematically with a 2 ohm load overall. So this works out perfectly.
http://mobile.jlaudio.com/support_pages.php?page_id=160
I.E. put all the positives together and all the negatives together.
i just found out my subs are 150 watt rms and 800 peak. how likely am i to fry up the subs i have been playing them hard for about half hour spans dont smell anything burning yet or the subs are getting hot. I think i am going to be fine what do you guys think i am newbie when it comes to hooking up audio
