One Good 10 and a Amp
Old Jan 16, 2009 | 11:17 AM
Good Ole' Boy's Avatar
I Know nothing about subs except for the fact that i need one good 10 (sounds clear and bumps pretty hard). I have 2 10 kickers right now wired up to a 1000w amp. Have know i idea whats the best way to wire it. But anyways i need a new 10 and a amp that matches up good, for around $400. Any suggestions/ recommendations would be helpful.
Old Jan 16, 2009 | 07:40 PM
RED4X4's Avatar
New or Used (like an ebay amp)?
Old Jan 17, 2009 | 10:56 AM
Low_e_Red's Avatar
You obviously dont work at a shop. Because if you did, ebay wouldnt be your recommendation everytime. You would start to see why the industry is tanking, why jobs are being lost and companies cut. Ebay and the other internet retailers are a HUGE part of this.
Old Jan 17, 2009 | 06:09 PM
probably a new one.
Old Jan 17, 2009 | 10:17 PM
novsun88's Avatar
So very true. Though everyone has to make money...
Old Jan 18, 2009 | 12:54 AM
RED4X4's Avatar
I don't. I wouldn't be able to afford and do the things I do with car audio if I did. The industry is tanking bc the newer products such as the ones you recommend are basically expensive junk. Also, most of the owners and employees at most of the car audio shops are idiots for lack of better words due to this site's rule on cussing.
probably a new one.
Alright let me look around.
Old Jan 18, 2009 | 03:52 AM
scottbigred's Avatar
Are you somewhere around 5 or 6 years old? Or are you just plain stupid?
Old Jan 18, 2009 | 12:04 PM
ARCuhTEK's Avatar
In a time of recession, I think buying used equipment is good, if you have to do so. If you can afford to support the economy, we all know that consumer spending is a big part of uplifting it. Most of my equipment is new, but I also choose some used equipment because I found NEW stuff at used prices from dependable sources.
His budget for an amp and sub are $400. That is not much but it can be done.
There is an Image Dynamics 10" ID10d-v3 for sale right now on ebay for $95 plus shipping ($35.00). New and from a dependable source. My best friend just ordered one and received it. It was legit. http://cgi.ebay.com/NIB-Image-Dynamics-ID10D4-V3-10-dual-4-ohm-subwoofer_W0QQitemZ170295169156QQcmdZViewItemQQptZ Car_Subwoofers_Enclosures?hash=item170295169156&_t rksid=p3911.c0.m14&_trkparms=72%3A1205|66%3A2|65%3 A12|39%3A1|240%3A1318
That will leave you with about $275-$300 for the amp.
One off the cuff recommendation is a good used DLS A6 mono amp. It runs 500w RMS at 4 ohm. But the above sub is a DVC so you will want to wire it to 2 ohms. At 2 ohms, the DLS A6 produces about 870w RMS. I have one of these amps, BNIB which I got for $300 shipped to me. I have it now....and its awesome.
http://www.dls.se/en/car/prod.html?produkt=en_109
I would have to take a close look at the sub to see how well these two match up, but its a start.
Old Jan 18, 2009 | 06:49 PM
RED4X4's Avatar
There is an Image Dynamics 10" ID10d-v3 for sale right now on ebay for $95 plus shipping ($35.00). New and from a dependable source. My best friend just ordered one and received it. It was legit. http://cgi.ebay.com/NIB-Image-Dynami...3A1|240%3A1318
Exactly...$400 is not a lot at all when it comes to car audio. That's why I recommend getting used, but taken care of stuff.
Old Jan 19, 2009 | 11:39 PM
alright ill look into that. thanks for all the input.
Old Jan 21, 2009 | 11:37 AM
Does this sub and amp match up? Again, i know nothing about this.
http://www.crutchfield.com/p_236T551...owAll=N&tp=111
http://www.crutchfield.com/p_675FRP4...ed.html?tp=115
Old Jan 21, 2009 | 04:33 PM
F150man21's Avatar
well it does but it wont be that loud at all. its a 2 channel amp. pushing one sub.
this is what i would buy for $400 it will sound awesome
http://www.onlinecarstereo.com/CarAu...roductID=19520
http://www.onlinecarstereo.com/CarAu...roductID=12512
good luck
Old Jan 21, 2009 | 11:43 PM
RED4X4's Avatar
good luck
No it won't. Many two channel amps are awesome BTW and so are single subs.
Old Jan 22, 2009 | 09:00 AM
alright well thanks. I might go with that.
Old Jan 22, 2009 | 09:56 AM
RegularJoe's Avatar
I just ordered a pair of the JL 10W3v2's. I can't wait. Based on the specs the shorter v2 version should fit in the supercrewsounds box with the extra 5/8" in height. I will be running the off of a pair of Alpine M350's. Each one will get 350 rms / 700 max. Mmmmmm.
