help asap noob
Old Dec 18, 2008 | 08:49 PM
baseballf150man's Avatar
help asap noob
I have two Kicker 10" cvrs. And I'm planning on adding a 3rd. My question is what amp do I need to run?
Old Dec 18, 2008 | 09:54 PM
1bad86vmax's Avatar
Are the Cvr's Single voice coil or dual voice coil and what Ohm Rating are they ?
Old Dec 19, 2008 | 12:42 AM
They are 2 ohm. not sure single or dual 50-400 watts RMS
Old Dec 19, 2008 | 02:03 AM
Low_e_Red's Avatar
Are they Dual 2's or 2ohms per sub
All CVR's made in the last 4yrs are DVC.
Old Dec 19, 2008 | 05:51 AM
1bad86vmax's Avatar
You need to know this before buying an amp . You must know what Ohm load you want your amp to see , and if said amp can handle that load .
Old Dec 21, 2008 | 12:39 AM
I suck at audio stuff so if someone could figure out all of this stuff for me it would be much appreciated.
Old Dec 21, 2008 | 07:51 AM
1bad86vmax's Avatar
We can't figure anything out , if we don't know what Ohm rating your current subs are .
Old Dec 21, 2008 | 02:11 PM
Like I said I suck at this I looked everything up and do not understand it. We somebody please figure this out for me? They are 2 ohm don not know if it is per sub or both together?
Old Dec 21, 2008 | 03:35 PM
dexx00420's Avatar
Where the hell are you gonna put it? I had issues getting two subs in mine.
Old Dec 21, 2008 | 11:29 PM
Under the rear seat. Already did this am looking to add third sub.
Old Dec 22, 2008 | 01:42 AM
Low_e_Red's Avatar
Take the sub out and take a DMM or ohmmeter to the terminals. OR you can find me the model numbers of the current subs and Ill be able to tell from that.
Old Dec 22, 2008 | 04:49 PM
This is the sub.http://www.hifisoundconnection.com/S...d/0/rid/123284Thanks
Old Dec 22, 2008 | 10:47 PM
1bad86vmax's Avatar
You will need a Mono amp that is 1 Ohm stable . You will wire the coils in Series and then Parallel wire all 3 subs . Your amp will see a 1.34 Ohm load . Will look like this .
Old Dec 23, 2008 | 01:58 AM
I cant fit another sub under seat. I was gonna put another cvr in a box ike this.http://www.audioboxesonline.com/Ford...C_p_2-139.html
Thanks for all of the help
Old Dec 23, 2008 | 02:00 PM
1bad86vmax's Avatar
Wouldn't you check this out first Before coming on here and wasting all of our time ?
