Amp problem... (Low_e & mSaLL)
I hooked up my JL 500/1 tonight and I can't get it to turn on. I know for a fact everything is connected properly and I do have a good ground connection. I just took out the Eclipse amp the other day and simply hooked the wires back up tonight. At first I thought it was the remote wire so I temporarily jumped a wire from +12v to the remote wire connection and still got nothing. Any ideas? Hopefully this amp isn't toast.
I did forget to unhook the (-) terminal once before a long time ago installing an Audiobahn amp back in high school. Everything was fine afterwards though. I realize you would want to unhook it when running power wire due to the risk of shorting out but what's the real purpose of doing this when connecting an amp? I know it's a stupid question but just thought I'd ask.
That's cool. I appreciate the help though!
This is what happened when I checked everything with a meter:
~ I first removed the power and ground cables from the amp and checked them to make sure everything was connected good leading up to the amp. It was all fine so I know I have good power/ground to the amp.
~ Then I checked the +12v and (-) terminals on the amp and that checked out fine as well.
~ Last I checked between the (-) terminal and the remote turn on terminal to confirm I was getting voltage with the head-unit on and I was.
I'm stumped because I figured if the amp has a power problem then I shouldn't be getting an audible sound from the meter when testing for continuity between the (+) and (-) terminals on the amp with no power or ground wire connected.
put the eclipse back and and return that 500/1. I'm not a fan of a amp I can't use lower ohms to pull more power out of.
Close to 0 ohms at the ground?
RCA's good?
12v's at the REM correct?
No shorts in the spk wire?
No short on the Spk coils?
But you shouldnt be showing any audible warning via checking continuity on the power to ground. Sounds like an amp short. Are you blowing fuses?
I just quoted your message and posted in it for ease:
12v's at the B+ correct?
~ Yep.
~ Yep.
RCA's good?
~ Yep.
~ Yep.
~ Nope.
~ No sub connected.
~ I'm not blowing fuses. I thought I blew the first one but after visually inspecting it and testing it with the meter I know I didn't. I don't have my steatlhbox connected to it yet. I was going to adjust the gains properly with the meter (as per JL's instructions) and I'm not getting any output to the speaker-outs due to the amp not turning on; that's when I knew something was wrong.
~ Yep.
~ Yep.
RCA's good?
~ Yep.
~ Yep.
~ Nope.
~ No sub connected.
