Constant power to amp
Old Nov 12, 2008 | 08:17 PM
Alkoholik's Avatar
Last weekend the family took a trip to minneapolis. Anyways, my parents wanted me to park my truck in the garage so nothing happened to it, so I did. Come back 2 days later, and my truck is dead. Come to find out my amp had stayed on and killed the battery.
I know it is the remote because if the truck is off and I pull the remote, the amp shuts off. I checked the back of the headunit and it looks just fine. What else could I check for?
This didnt ever happen before I parked it in the garage, so dunno what happened
Old Nov 13, 2008 | 12:57 AM
Low_e_Red's Avatar
What wire is it hooked to behind the HU?
Old Nov 13, 2008 | 01:45 AM
C. Whammy's Avatar
but if it didnt happen until he parked in the garage.......
Old Nov 13, 2008 | 04:55 AM
FX4_2003's Avatar
I had an alpine stereo in my wifes car do this.. For some reason something inside the head unit made the amp on and off lead stay hot .. They Guy at Automotive Audio said it was a radio defec and gave us a new unit... never had the problem again.. My Pioneer in my truck the amp power lead wont even work so I have the amp on/ and off hooked to a fuse that turns on and off with the key..
Old Nov 13, 2008 | 07:10 AM
1bad86vmax's Avatar
So just hook the remote wire to a Switched + in the dash .
Old Nov 13, 2008 | 02:29 PM
Low_e_Red's Avatar
Acc wire behind the radio works well for that.
Old Nov 13, 2008 | 04:22 PM
Alkoholik's Avatar
It's hooked to the remote like its supposed to be. guess I will just have to install a switch then
how do I go about doing that?
Old Nov 13, 2008 | 06:59 PM
1bad86vmax's Avatar
Why do you need to install a switch ? Just unhook the remote wire from your radio and hook it to the Acc wire(Red on aftermarket Radio's) that your radio is connected to . When you turn the key on , your amp & radio will turn on .
Old Nov 14, 2008 | 12:44 AM
Low_e_Red's Avatar
^ is the correct way.
To install a switch. Cut wire and attach one side to one contact the other to the other...
Old Nov 14, 2008 | 09:09 AM
Landon Kolesar's Avatar
If this never happened before, then i would say its your amp.
Low e red.... what should you tune your subs to in a sealed box? Got 4 kicker L5s
Old Nov 14, 2008 | 11:07 AM
Low_e_Red's Avatar
Start a new thread.
