confused
Old Oct 28, 2008 | 11:57 AM
g_h2o's Avatar
Smile confused
hi ther ppl. I have an '06 f-150 lariat.i got 3 prolems. I am trying to hook up an amp and keep my factory head unit. everything is hooked up but my remote wire. where do I hook that up and keep it on till the stereo goes off? keep in mind that there's a little delay when I shut the ignition off to when the stereo goes off.
2nd problem. my right rear speaker wires are yellow with red stripe and purple with white stripe. which is positive and negative?
3rd question: how do i hook up my line in button from the head unit? and what can i hook it up to? when i push AUX it goes from AUX 1, AUX2, AUX3, and line in. the aux controls my sat radio, but the line in doesnt do anything
Old Oct 28, 2008 | 12:03 PM
Low_e_Red's Avatar
1. Wire the remote wire to the Acc wire. It will be EITHER Pink/Blk or Lt. Grn/Yellow
2. Rear Spk wires should be Orange/Red (+) and Brown/Pink
3. You will need a Peripheral piece to make the line-in work.
Old Oct 28, 2008 | 10:33 PM
g_h2o's Avatar
thanks
thanks you for your help.
1: for the power... this wire should keep it on till i open my door or it shuts off automatically?
2:yellow with red stripe and purple with white stripe... these are the wires i got in my right rear speakers... there's no orange/red nor brown/pink.
3: where can i get a peripheral? thanks for your help again
Old Oct 29, 2008 | 02:34 AM
Low_e_Red's Avatar
Its nothing.
1. Yes, until a door is opened or 10 min after shutdown.
2. One closest to the tab for the connector.
3. BBy, CCity or a local audio store.
Old Oct 30, 2008 | 03:42 PM
Kevin K's Avatar
Is there a location in the fuse box?
Old Nov 1, 2008 | 03:22 AM
Low_e_Red's Avatar
That is rigging.... Twisting around a fuse is HALFASS and can cause a fire (Ive seen it many times first hand...)!
Go behind the radio or underdash.
Old Nov 3, 2008 | 10:57 AM
g_h2o's Avatar
ok i use the yellow/green for my remote and that fixed the problem. it works great thanks. i also use the wire closes to the tab as a positive and that works good to. still missing with the in-line input. ill let you all know. thanks for everyones help, comments and feedback.
