What is big 3 upgrade?
The Big 3 Are:
1. negative battery wire to ground - just replace the negative batt. terminal and wire and ground it to the factory location
2. engine block to ground - replace the ground wire from the engine block to the chasie with a bigger wire (maybe 4 guage)
3. alternator to batt - add a fused wire from the postive post on you alternator (the one comming from the battery) to the postive terminal on your battery. DO NOT exchange wires just add a extra one. make sure it fused the same size as your factory fuse.
hope thats helps
Note on #2- Some cars have a batt-engine block connection stead of chassis to engine block...
hope thats helps
The Big 3 Are:
hope thats helps
hope thats helps
Search!!!! I know I alone have already responded to countless threads explaining why its a MANDATORY upgrade and how to do it.
The Big 3 Are:
hope thats helps
hope thats helps
Do 1/0 awg wire, you'll always want to upgrade your stereo, go with the biggest wire possible. All 3 of the upgrade wires should be the same size.
About the fuse...fuse size should be based on the capacity the wire can carry, NOT the same as factory no no no. Example: my Knu 1/0 wire is rated for 250A, so i have a 250A fuse on it. Simple enough, eh?
Bolded the parts i see wrong with your post, otherwise it looks good.
geez, i just copied and pasted the thread from the only car audio forum im on
http://www.soundsolutionsaudio.com/f...c=200&hl=big+3
Right, but it should certainly not be higher than the wire's capacity, and certainly not the same as stock.
Thats why I said for the lesser. If the wire can carry less current then fuse it for that. (IDK why you would do it then... But still) Or if the wire can carry more than the power produced then fuse for the power produced.
Im really getting sick of websites like CA.com. Get a bunch of n00bs that "KNOW IT ALL AND THEN SOME" but dont know chit. Then they believe they are correct and will tell off ppl that actually know what they are talking about...
You know King Ranch is one of the most looked up to people on there now??!?!? Its another sad day in that hell.
