Where to get power?
Old Aug 1, 2008 | 09:42 PM
James321's Avatar
Where to get power?
Ok, I know I should go to the battery for my amp, but is there any other place inside the cab I could draw from. I am using a 300 watt amp, not too big. I have a 05 supcab xlt. Thanks for any info.....
Old Aug 1, 2008 | 10:52 PM
Proto's Avatar
no.... definitely not... going to the battery for any kind of amplifier is the only place thats safe on an f-150.
Old Aug 2, 2008 | 12:57 AM
v8isgr8's Avatar
X2!! definatly go straight to the battery!!
Old Aug 2, 2008 | 03:06 AM
C. Whammy's Avatar
yea, unless you want to be the first to try to pull 300 watts of power from a 16 gauge wire that is probably fused at like 5 amps.....then i would say x3
Old Aug 2, 2008 | 01:41 PM
James321's Avatar
thanks for reply
Just wanted to make sure. I usually go to the battery with the amp, just wanted to know if there was a source in the cab I could got to without going trough the firewall. By the way, which "hole" or "area" should I choose to go through the firewall. Have installed amps in the past, just not on the new body styles....thanks again for all the help..
Old Aug 2, 2008 | 09:25 PM
Low_e_Red's Avatar
Right behind the battery, there is a grommet.
P.S. GO TIGERS!
Old Aug 3, 2008 | 07:17 AM
James321's Avatar
Thanks for the reply Red
P.S. GO TIGERS!
Will proceed to the battery, thanks for the info. I hope the Tigers can prove the experts wrong and do better than #6. They alway under estimate LSU....later....
Old Aug 6, 2008 | 05:53 PM
IROC it's Avatar
I also have a little pictorial in my signature about this... my grommet of choice was on the driver's side.
I never had a problem with it.
Old Sep 1, 2008 | 11:30 PM
iRmark88's Avatar
yeah hit the one on the driver's side. it's the best one to go through on the new body style trucks
Old Sep 4, 2008 | 01:51 PM
Low_e_Red's Avatar
Umm, NO IT ISNT.
Old Sep 4, 2008 | 06:55 PM
abervintageman4's Avatar
Umm, NO IT ISNT.
duh! everyone knows the easiest way to do it on ANY car is run a wire through the window and in a crease between the hood and another panel, you guys are retarded!
Old Sep 5, 2008 | 12:54 AM
Low_e_Red's Avatar
No, gosh. Dumby. Try just mounting the amp in the hood. Fuses are a PITA and worthless....
Old Sep 5, 2008 | 03:32 PM
what was i thinking?! fuses are pointless, if your stuff shorts out you can just electrical tape over the charred insulation
Old Sep 6, 2008 | 12:20 AM
Low_e_Red's Avatar
I literally just worked on a Jetta that completely fried all insulation off of the wire. It no **** caught fire under the dash and the copper was like burnt paper (touch it and it falls apart).
He wrapped some copper (18ga remote wire) around a 25A fuse (of course the hot side of the fuse) and decided to use it for power wire, well in putting everything back together put a screw threw it... Starts it up and poof fire. Melted through his fuse panel... HORRIBLE. He also did it 2x...
I laughed at the shear stupidity (P.S. He is the asst manager at my new CCity...)
Old Sep 8, 2008 | 04:31 PM
wow....just speechless, i am suprsided that people even go to that level, i had some fog lights that shorted out, i went to replace the fuse and the two ends touched each other and poof up in smoke the wire went i just took em out
