quick help
Old May 24, 2008 | 06:35 PM
Rao11010's Avatar
Exclamation quick help
how do you remove the back part of the back seat? do you have to take out the bottom first? i'm trying to mount the amp against the back wall so does anybody have good advise? everything is happening tomorrow so the quicker the better
thanks ryan
Old May 24, 2008 | 08:16 PM
shanecaseber's Avatar
back side first Its a pain you need a long screw driver and push in 2 black clips at the 2 ends and lift up at the same time once I got it, I zip tied them so the back slips right off some one posted a how 2 do a search that shows some pics of the clips but they are about 7 inchs in from the ends and pop off your seat belt cover at the top of the seat 2 bolts for this see the right side clip by the x in the end
Old May 24, 2008 | 08:19 PM
jimc2004's Avatar
Originally Posted by shanecaseber
back side first Its a pain you need a long screw driver and push in 2 black clips at the 2 ends and lift up at the same time once I got it, I zip tided them so the back slips right off some one posted a how 2 do a search that shows some pics of the clips but they are about 7 inchs in from the ends and pop off your seat belt cover at the top of the seat 2 bolts for this
x2. zip tie those suckers. You may spend a good bit of time trying to find those clips and get the seat loose.
Old May 24, 2008 | 08:50 PM
Rao11010's Avatar
i took the top cover of the seat belt at the top but did not see any bolts, are they hidden?
Old May 24, 2008 | 09:08 PM
if you pop off the lil cover then you should see 2 nuts to un do not bolts sorry
