My system (pics) need amp help
Old Apr 25, 2008 | 05:23 PM
2007 FX2's Avatar
Ok, heres what i have:
HU- KENWOOD DPX-502
JL TR570-CXI -FRONT DOORS
JL TR650-CXI -REAR DOORS
KICKER CVR 10'S X2
KICKER ZX 700.5
Custom Fiber Box
Sirius
The problem is the amp can't push the subs. I'm new to this stuff and still trying to learn all this ohm/watts and RMS stuff. Unfortunitly I bought the amp off a friends advice, so anyway whats a good amp that will fit behind the back seat to push just the subs? And of course i need to do this for as cheap as possible. The wife is already pissed i need to buy more.
The HU and amp bass control--
The HU--
Subs and amp--
[img=http://img109.imagevenue.com/loc1006/th_57854_DSCF4260_122_1006lo.JPG][img=http://img102.imagevenue.com/loc1009/th_57870_DSCF4267_122_1009lo.JPG][img=http://img104.imagevenue.com/loc654/th_57872_DSCF4266_122_654lo.JPG]
Thanks in advance !!
Old Apr 26, 2008 | 02:58 AM
FiLiPiNo AkO's Avatar
crutchfield may still have a sale on some 07 models on kicker amps. i bought a 750.1 from them for 300 and it actually puts out 940. it'll push those to the limits if not more!
Old Apr 26, 2008 | 10:52 AM
Justi's Avatar
It will depend on whether or not you have 2ohm or 4ohm dual voice coils on your woofers.
If you have the 4ohm version you can run them at either a 1ohm or 4 ohm load.
If you have the 2ohm version you can run them at either a .5, 2, or 8 ohm load.
The cheapest "power" is available in amps that can handle a 4ohm bridged single output. Getting 2ohm and below stable amps can get expensive quickly.
You're going to want an amp that can send 600 watts RMS at a minimum to a single channel. If you get a good deal on a more powerful amp you can just turn the gain down a bit. It's better to have too much power available than not enough.
Old Apr 26, 2008 | 11:46 AM
2007 FX2's Avatar
They are 4 ohm dual
Old Apr 27, 2008 | 01:45 PM
dirtyd88's Avatar
i wish i could do that with my amp, stick it in the box like that.mine sits under my driver seat.
Old Apr 27, 2008 | 05:53 PM
novsun88's Avatar
why don't you put it on the rear wall between the wall and seat?
Old Apr 27, 2008 | 11:04 PM
Low_e_Red's Avatar
Buy two CVR's with 2 ohm DVC's and then rig it to that 700.5. That sucker is an awesome amp. I really like installing those.
