Low E JL 500/1 Help Please
Old Mar 22, 2008 | 12:11 PM
daculatruck50's Avatar
Ok. i just purchased a 500/1 and AVIC-D3. I already had a 300/4. Now which RCA's should i use for the amps? Is the subwoofer pre-out good for the 500/1 and the front pre-out good for the 300/4? Or sound i run the front pre-out to the 500/1 then send the same signal to the 300/4 by the 500/1's preout? I think the 500/1 likes a full range signal not just the sub pre-out but i could be wrong. Please help.
Old Mar 22, 2008 | 07:37 PM
TRUEBLUE2004's Avatar
What are you running the 500/1 to. I would think (hope) a sub. So therefor I would say the sub out but I have no experiance w/ aJL amp. Also I would run 2 pairs of rca's t the 300/4 amp. That way you can have f/r fadeing for that amp.
Old Mar 22, 2008 | 08:08 PM
The 500/1 is hooked to a 12" Type-R and i have the 300/4 hooked up to JL XR 6.5 Components. My question is what pre-out should go to the 500/1 i think it is supposed to be full-range. I dont think the 500/1 works good with the sub pre-out. But i could be wrong.
Also i have the 300/4 bridged to 150X2. The XR's are 4 Ohm. So when i look up on the JL Voltage chart is that 4 Ohms bridged or 8 Ohms bridged?
