can a push more from my amp?
Old Jan 29, 2008 | 12:20 PM
306stang's Avatar
here's what i've got:
kicker 200.2 amp
kicker cvr 10 2ohm
there are four posts on the back of the sub.
there is a jumper from one of the pos to one of the neg
then the other + / - are run to the amp.
is there another way to wire it up to get more power?
i've bridged it before then 10 secs after it being on it shuts off.
Old Jan 29, 2008 | 01:45 PM
Bartak1's Avatar
Sounds like you have it series wired for 4 ohm....most amps only stable down to 4 ohm bridged so if everything else if good, its kind of odd that its shutting down bridged.
Unless only the pos. and neg. of one coil are hooked up and the other coil is shorted out. Which in that case you would have a 2 ohm load on the amp, half the power handling, and who knows what for any T/S parameters.....
Old Jan 29, 2008 | 01:52 PM
Devildog101's Avatar
Feel like coming to Tampa one weekend?
Devildog101
Old Jan 29, 2008 | 01:59 PM
306stang's Avatar
so should i hook both neg's and pos's up then to the amp? (parrallel, i think)
Old Jan 29, 2008 | 04:16 PM
dconder's Avatar
I would not do that. If you hook both positives together and both negatives together, then you are presenting a 1 ohm load to the amp. Most likely the amp will just shut off if you try to run it bridged at 1 ohm. Like Bartak said, most stereo amps are only designed to run at 4 ohms bridged. A few higher end amps will run 2 ohms bridged. I personally have not heard of a two channel amp that will run at 1 ohm bridged. There may be some but the Kicker is not one of them.
Old Jan 29, 2008 | 05:03 PM
306stang's Avatar
super
Old Jan 29, 2008 | 05:46 PM
Crewwzin's Avatar
Devildog101
Why would he do that when he could just come to the other side of Choctawhatchee Bay and see me?
Old Jan 29, 2008 | 11:05 PM
306stang's Avatar
i really don't think i've got too many options except to get a new amp.
if you want to look at it just let me know
Old Jan 30, 2008 | 03:12 AM
Low_e_Red's Avatar
I remember seeing one or two... I will have to find them again. But ya .5ohm stable stereo and one ohm bridged... DEFINATELY NOT A KICKER!!!
Old Jan 30, 2008 | 09:02 AM
dconder's Avatar
I know some old school "cheater amps" that would do it but, they are rare and expensive.
Names like Orion, PPI, Phoenix Gold, Linear Power. Not new stuff but the old stuff would do it. I think even the early Kicker ZR stuff might have been able to pull it off.
Old Feb 16, 2008 | 09:49 PM
skiptemp's Avatar
Kinda like my little friend here!!
This is what you want. Normally 25w X2 at 4ohm. Stable to 1 ohm bridged 400w X1 and .5 ohm stereo 200w X2. Make sure its the digital reference series though. Once in a while you can still find them on e-bay. I got this one about 18 years ago when I used to work for Orion in Phoenix.
Old Feb 17, 2008 | 12:05 AM
skiptemp's Avatar
Also check out US Amps:
here are their stats for some comp amps.
SPECIFICATIONS:
Watts per
Channel
Bridged
Output:
THD:
S/N Ratio:
Frequency
Response:
Fuse:
USA-100HC VLX-25
(Pictured)
4 ohms: 50Watts 12.5 Watts
2 ohms: 100 Watts 25 Watts
1 ohm: 200 Watts 50 Watts
½ ohm: 400 Watts 100 Watts
¼ ohm: N/A 200 Watts
800 Watts 400 Watts
@ 1 Ohm @ ½ Ohm
<.006% <.006%
>100db >100db
5Hz-50KHz 5Hz-50KHz
225 Amps 225 Amps
Old Mar 3, 2008 | 06:18 PM
bigtex44's Avatar
Tsk, tsk, tsk. How soon we forget about the old Kicker XS50 and XS100 amps, lol.
But I agree, if its a modern day amp, .5ohm stable stereo and one ohm bridged... DEFINATELY NOT A KICKER!!!
