what amp should i get???
Old Jan 28, 2008 | 11:03 PM
rolltide4x4's Avatar
i just got 2 12in pioneer shallow mount subwoofers
they both HANDLE 350 rms at 4ohm
so i need a dual amp under or around 700watts
what would u recomend????
Old Jan 28, 2008 | 11:30 PM
Bartak1's Avatar
What impedence are your subs (dual 4, single 4, etc) and how much are you willing to spend?
Old Jan 29, 2008 | 07:13 AM
there both 4ohm.... around 350
Old Jan 29, 2008 | 09:17 AM
carguyingeorgia's Avatar
they both put out 350 rms
Let me offer a disclaimer that I am not trying to be a smart butt; however, this is the first time that I understand a topic well enough to correct something. So here it goes:
Subwoofers (or speakers in general) do not "put out" power, they "handle" power; amplifiers "put out" power. Therefore both speakers can handle 350 watts RMS.
Rolltide, don't worry about it, Bama fans need help sometimes, and who better than a Dawg to give it.
Old Jan 29, 2008 | 04:25 PM
aight dude thanks soo much... but u didnt answer my question at all.. all i can say is 12 NATIONAL CHAMPIONSHIPS..
just keep the 27th of September in mind
Old Jan 29, 2008 | 04:55 PM
Sorry, I couldn't resist. As far as your question, I don't know enough about it to make a recommendation.
I'm looking forward to Sep 27th between the hedges; should be a good warm up for our national title run.
GO DAWGS!!!!
Old Feb 1, 2008 | 06:06 PM
817boy's Avatar
ok you need to check if they are single 4 ohm or dual 4 ohm models. Ok If they are single 4 ohm models you will need an amp that can handle 700 watt rms at a 2 ohm load. And you will wire them like this http://www.crutchfield.com/learningc...4%2Dohm%5Fmono
if they are the dual 4 ohm models then you will need an amp that can handle 700 watt rms at a 4 ohm load (which will be a big amp). you will wire these like this http://www.crutchfield.com/learningc...4%2Dohm%5Fmono
Please let me know what model you have so i can suggest some amps for you.
Old Feb 1, 2008 | 07:18 PM
Crewwzin's Avatar
Or a 1 ohm load...which isnt near as hard to find and considerably cheaper than a a/b 700 watt amp.
Old Feb 1, 2008 | 07:51 PM
817boy's Avatar
true I just never like running at a 1 ohm load. never soulds right but idk
Old Feb 1, 2008 | 10:53 PM
Crewwzin's Avatar
huh? never sounds right? You confuse me grasshoppa. Have you ever ran a class D amp on a 1 ohm load? Thats what they're (most of them) designed to do...1 ohm. And they're about 90% efficient as opposed to 60-65% for A/B amps.
Old Feb 2, 2008 | 10:36 AM
817boy's Avatar
I never ran at 1 ohm but me and my friend have the exact same system and mine is ran @ 2 ohm and his is @ 1 ohm and even he will say my system takes his out.
Old Feb 2, 2008 | 01:47 PM
Crewwzin's Avatar
Without knowing a little more about both of your systems, I cant say why this would be. If you have the EXACT same system, he is theoretically running twice the power that you are (if both amps are 1 ohm stable). Difference in vehicles, boxes, position of the box in the vehicle all have a huge effect on output.
Old Feb 3, 2008 | 11:58 AM
http://www.crutchfield.com/App/Produ...ures_and_specs
I have 2 12" pioneere shallow mount 4ohm's but i dont know if they are single or dual
Old Feb 5, 2008 | 03:31 PM
1bad86vmax's Avatar
Single 4 OHM
Old Feb 5, 2008 | 08:19 PM
Low_e_Red's Avatar
Let a Bulldog get it... PLEASE. We happen to be the national champs, plus we went to the SEC championship. (Much Love)
GO FIGHTING TIGERS FIGHT ALL THE WAY!
