Amp for Mojo 12"
Old Jan 19, 2008 | 07:38 PM
CRF250rider1000's Avatar
Amp for Mojo 12"
Ok I am pretty sold on the Memphis mojo 12" subwoofer. I am looking at some different amps though. Thanks guys! Oh yea, and where is the best place to buy memphis products?
http://www.woofersetc.com/index.cfm?...roduct_ID=2131
Would this give me 1000w to the mojo 12" or do I need more?
http://www.woofersetc.com/index.cfm?...roduct_ID=4738
Old Jan 20, 2008 | 01:58 AM
Low_e_Red's Avatar
You need more. Or a MOJO with either Dual 4's or Dual 1's.
Old Jan 20, 2008 | 08:22 AM
Crewwzin's Avatar
The Memphis 1100D in either the PR series or the Mclass is a perfect match for that sub if you're not competing. I have seen as much as 8000 watts on one of those subs, but that was just for competition. If you get a true 1K amp, that will be plenty for what you want to do. More important than the amp is the box. Build a properly tuned vented enclosure and that sub will absolutely QUAKE. Memphis all the way!
Old Jan 20, 2008 | 07:32 PM
That sounds good I will look into that amp. Nothing is going to happen until summer but what kind of ported box could I build to fit in the center of the back seat? I was going to stay with the sealed enclosure just because of space, but if I can fit a ported enclosure while still having the back two seats open I will definitely do that.
Here are the specs for what it needs to be, but does it need to be a square box or what can I do with it? Thanks!
http://www.memphiscaraudio.com/LiveI...cumentURL2.pdf
