Sub Volume Setting
Old Jan 8, 2008 | 02:52 PM
carguyingeorgia's Avatar
Sub Volume Setting
The Alpine 9885 HU I have has a separate level for the Sub Out RCAs on the back which I will be using. When I set the gain on the amp, at what level should I have the Sub Out volume set to? The Kicker ZX400.1 amp manual says to turn the main volume up to about 3/4; should I do the same for the Sub Out?
I don't plan on using the bass **** that came with the amp since the HU has the separate setting for the Sub. Once I set the Sub Out level on the HU and adjust the gain on the amp, should I be careful not to go above that Sub Out level or risk blowing the sub? This is my first experience with this type of setup, and I just don't want to do something that is going to tear any of the equipment up.
Old Jan 8, 2008 | 04:05 PM
edwards's Avatar
on my head unit i have the sub volume set at 0. then i set the gain on my amp to whatever i desired it to sound.
that way when im listening to music i can either turn the bass up or turn it down using the HU.
Old Jan 10, 2008 | 02:46 PM
Rather than starting a whole new thread, I just decided to use a previous one for this topic.
I have begun the install on my system and just thought I would post the link to some photos I have taken so far. Last night I got the passenger side doors completed with two layers of edead, the new speaker wire routed from behind the back seat where the amps will be located, and the door speakers installed. I would appreciate any comments or suggestions that people may have from looking at the photos of how I have everything set up. I'd rather get it right now than have to go back and do it all over again.
One question I did have was whether I should have any type of speaker baffle for the door speakers. The factory speakers didn't have anything, but I didn't know for sure if it was necessary.
Oh, almost forgot the link.
https://www.f150online.com/galleries....cfm?num=15504
Old Jan 11, 2008 | 12:46 AM
benkr16's Avatar
it looks pretty good so far!...where did you get the edead and how much was it? And also, Are you going to use your back door speakers?
Old Jan 11, 2008 | 07:40 AM
I got the edead off of ebay for $1/sq ft; however, if you go to this link you can get it for .80/sq ft.
http://www.edesignaudio.com/edv2/pro...1ee390b8e7119f
Do you mean the factory speakers? If so, then I'm not going to be using them, but probably will keep them in case I get rid of the truck any time soon in which case I will swap them out for the Infinitys. Besides, one of them is blown anyway.
Old Jan 11, 2008 | 12:50 PM
Devildog101's Avatar
Looking good!
Keep up the work, and keep posting more pics in your gallery througout the install.
let us know how it sounds when completed.
Devildog101
