Wiring harness adapters
Old Oct 31, 2007 | 07:59 AM
Banedog's Avatar
Getting ready to install a MB Quart amp in the dash. Need to wire up a LOC and outs to the speakers.
Does anyone make a wiring adapter like the Scosche FD23B and FD23RB wired together? So you only cut the wires you need. Instead of splicing everything one by one.
Hope that description made sense....
Old Oct 31, 2007 | 08:40 AM
07Redfire4x4's Avatar
Check out this link:
https://www.f150online.com/forums/sh...light=line+out
Old Oct 31, 2007 | 10:09 AM
Banedog's Avatar
Originally Posted by 07Redfire4x4
Right... That's what I'm doing, but wondering if they make it in one piece. Instead of having to splice the wires that are not used in between the 2 connectors.
I've used the same type thing before in the telecom industry. Just wondered if they made them for this application.
Old Oct 31, 2007 | 11:27 AM
MACH1_69's Avatar
I did alot of searching before I did mine. Could not find a "all-in-one", But this is what I ended up with.
I soldered the wires and heatshrinked each one, and then loomed all together.
No butt connectors at all.
Keep in mind too, compare all the terminals that are used in the connectors. If I remember correctly I had to swap/switch 2 pins so it would match up with the factory harness. Nice Plug and Play.
Old Oct 31, 2007 | 12:13 PM
Banedog's Avatar
Ok cool... Thanks for the responses.
Nice job on that harness Mach1. And thanks for the tips!
