How to keep AMP cool?
Old Sep 3, 2007 | 01:05 PM
BrewScrew's Avatar
I have mine installed under the seat in the bal and it gets hot...Any things out there to keep them cool?
Old Sep 3, 2007 | 04:51 PM
TRITON_2002's Avatar
Heat is the byproduct of making power, so it's natural for the amp to be hot. It's a matter of how hot is too hot. The cooler the amp stays the longer it will work. The best place to mount it would be out in the open with plenty of fresh air movement, of couse most of us don't like to see the amps, so they end up under the seat, behind the seat, ect. If your amp already has a cooling fan, make sure it is not blocked. If it doesn't have one, you can add one or two. Also put some space between the carpet and the amp for more air flow. Bazooka has/had some amps with built in liquid cooling, like a radiator, sounded pretty cool, not sure if they are still around
Old Sep 3, 2007 | 09:44 PM
Bartak1's Avatar
Is there plenty of room around the amp for proper cooling and such? Not a bunch of crap piled ontop of it either (coats, rags, tools, etc).
If its not overheating enough that its going into protect I wouldnt worry to much about it, but if you are wanting a little cooler, try some small 12v computer case fans. You can get them cheap at some place like Radio Shack
Old Sep 3, 2007 | 10:35 PM
jmt0645's Avatar
i've got 2 60mm fans on my comp amp, and 2 120mm fans on my sub amp. just in case!
Old Sep 6, 2007 | 01:07 PM
BrewScrew's Avatar
Any pics of how to install? (power)Thanks..
BrewScrew's Avatar
Old Sep 6, 2007 | 01:48 PM
Bartak1's Avatar
If you only have one or two smaller ones you can wire them right into your amps turn on wire.
If you are going to have a larger amount I would run a separate line from a switched wire in the fusebox or somewhere...
Old Sep 6, 2007 | 04:50 PM
jmt0645's Avatar
yep, both my comp amp and sub amp, and all 4 fans are controlled by a 40amp relay ( fused at 7.5 amps however). my 2 60mm fans blow 35 CFM each and the 120mm fans blow 115 CFM each. the loudest i've recorded them to be yet with the back seat off is ~ 39.5 DB. i'll get picks in a few.
Old Sep 6, 2007 | 11:02 PM
Bartak1's Avatar
Haha, you like to play around with that little db meter huh
Old Sep 6, 2007 | 11:11 PM
jmt0645's Avatar
ya, it gets me through my day
it makes me wish i still had my termlab
Old Sep 6, 2007 | 11:48 PM
Bartak1's Avatar
I want a TermLab
I would only use it like 5 times then it would probably sit though
Old Sep 7, 2007 | 12:14 AM
jmt0645's Avatar
I want a TermLab
i got mine from an audio shop that closed down a few months ago, i sold it on ebay for twice what i paid
Old Sep 7, 2007 | 12:13 PM
BrewScrew's Avatar
Pics?
Old Sep 7, 2007 | 12:19 PM
jmt0645's Avatar
my bad
sorry, kinda forgot the pics, the first one is my comp amp, the 2 60mm fans are just to the left.
the second one is the sub amp, you can just make out the front 120mm fan to the left side of the amp (which just happens to be the power supply side{the hottest part}) the 2nd fan is behind the first.
also in the first pic you can see the relay i use to control it all.
Old Sep 7, 2007 | 02:01 PM
DRJ's Avatar
DRJ
I usually like to put about a 1/4 inch of space between the mounting surface and the amp, It helps with dispersion of heat quite well
I like to use 10 ga or 8 ga grommets...or I double up the 4 ga with 8 ga for added support on larger amps.
