Routing power cable?
Old Jul 24, 2007 | 12:29 AM
awt's Avatar
awt
Where the best place to run my amp's power cable thru the fire wall in an 02 supercrew?
Old Jul 24, 2007 | 01:53 AM
DRJ's Avatar
DRJ
Firewall Grommet
There's a large rubber grommet on the firewall behind the pedals, you can see it if you stick your head in there, you can see it from the engine bay too, just pop it out and cut a slit for your power wire andrun it through!
Old Jul 24, 2007 | 04:21 PM
Bartak1's Avatar
Another option would be the grommet under the passengers side sill plate.
Both will work great.
Old Jul 24, 2007 | 04:50 PM
puddle jumper's Avatar
i went with the one right behind the battery
Old Jul 24, 2007 | 04:51 PM
Dallasstars10's Avatar
What is the passengers side sill plate exactly. thanks!
Old Jul 24, 2007 | 05:37 PM
Bartak1's Avatar
Dallas, the peice Im referring to is the long plastic piece that runs from the front of the truck to the rear on the floor. It holds down the edges of the carpet where it meets the door. Has the ///////FORD////// looking pattern molded into it.
Here is a pic of one...the peice towards the bottom that says 'Denali'
THATS your sill plate
Old Jul 24, 2007 | 06:05 PM
awt's Avatar
awt
Thanks guys
