What ohm load is this?
Old May 1, 2007 | 05:16 PM
red99l!ghtning's Avatar
Hey guys. Im runnin to treo TSX 10.22, there dual 2 ohms on each. what ohm level would it be running at with all of it hooked up? or does it even change?
Old May 1, 2007 | 06:21 PM
south_ms_sprcru's Avatar
series the voice coils of each sub, this would make each sub a 4 ohm load, then parallel the pair of subs down to a single 2 ohm load... basically your going from xx xx xx xx -> xx xx -> xx
that little diagram may mean nothing at all to you but i was trying to use a visual..haha
Old May 1, 2007 | 09:07 PM
Impact9's Avatar
http://www.bcae1.com/spkrmlti.htm
Old May 2, 2007 | 01:36 AM
thanks impact...i was racking my brain trying to figure out a way to visually explain what i was typing..haha
Old May 3, 2007 | 12:51 PM
mikey7182's Avatar
You can wire each sub in series to achieve a 4 ohm load or in parallel to get a 1 ohm load. If you are running 2 subs, you can go to 8 ohms, which would be both subs wired in series, back at 2 ohms, which would be wired in series parallel, or .5 ohms, which would be wired in parallel. I like RF's Subwoofer wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Just put in the number of woofers, the impedance of each one (single 4 ohm, dual 4 ohm, etc) then click on the available wiring options and it will show you all the possibilities.
Old May 4, 2007 | 11:39 AM
051fdrof's Avatar
That's a great link
