Will Distribution Block Work For This?
Old Apr 30, 2007 | 10:09 AM
tsvsega's Avatar
Question Will Distribution Block Work For This?
Hey guys i have a new amplifier that just came in. The Power Acoustik Plasma TS960-4 960W 4 channel amp. This is rated for 100W X 4 and i will be using it for the front and back speakers. It requires a 4 gauge power and ground. I also have the Kenwood self-enclosed self-powered KSC-SW1 150W
subwoofer. This sub uses a 14 Gauge power wire with a 10amp fuse. I will be setting the gain on the amp to about 50% as my speakers are rated for 50W RMS.
I have ordered a 1000W 4-gauge Monster Amp kit.
My question is this:
Will it be safe to use the 4 Gauge in 8-gauge out power distubution block that comes with the amp kit to power the amp and sub, or should i just run the sub power seperate?
Thanks,
tsvsega
Old Apr 30, 2007 | 12:09 PM
dconder's Avatar
Thanks,
tsvsega
I think you would be fine running 4 awg to 8 awg thru the distro block. Just make sure you either use the same 4 awg to 8 awg for ground or run at least 8 awg ground from the amps to a common ground spot. All ground wires should be at least the same size as the power wires to the amps.
Old Apr 30, 2007 | 03:39 PM
Im_SCrewed's Avatar
X2, you should be fine.
Also remember that any wire's ability to carry the load is affected by diameter and length. The shorter the 8 awg runs the better.
