Amp for compvr10s
Amp for compvr10s
I have a pair of kicker compvr10s. They run at 300RMS at 4 ohm each. To make sure I am looking at the right amps, i need an amp that runs at:
300RMS x2 @ 4ohm or
600RMS x1 @ 4 ohm
IS this correct? Does anyone have any suggestions for an amp for those subs?
300RMS x2 @ 4ohm or
600RMS x1 @ 4 ohm
Those are dual voice coil right? You'll need decided how you want to wire these up you could go 4 ohm but I would probably go with a 1 ohm load.
http://www.bcae1.com/spkrimp.htm
about half way down the page you'll see this image:
That is the correct wiring for a 4 ohm load.
On that same page right above that image is the correct wiring for a 1 ohm load.
It's a tough call but I would probably wire it up for a 1 ohm load and get a mono block amp like perhaps a HiFonics TXi 7506
What sort of budget are you looking at? Also do you have a aftermarket headunit?
yeah, thats what kicker suggests and the subs are dual coil. My budget is limitless I guess but I dont want to spend an arm and a leg. My headuint is a kennwood ddx7015
I'm also gettin componet speakers (125rms) for the front and a set of for the back 35 (rms). I dunno if that will affect anything bc i planned on gettin a seperate amp for these
35w rms is pretty low might be hard pressed to find a quality amp that will run at that power level. I would get something with comparable power ratings, or put some 6.5" midbass in the back. With a budget like that I would look at Rainbows. Search these forums and you'll see they are quite popular.
I have the money, i just dont want to blow alot. The Rainbows just seem to ne too much $$$ and I dont like the idea of having to mod it in order for it to fit
