Thank you guys for the help!
Old Mar 26, 2007 | 06:51 PM
Hiloboy's Avatar
Hey Guys...Thanks for the help. he amp fit fine behind the seat, but it was a tight fit. Wanted to mount the amp on a 3/4" pressboard, but no such luck. Too thick. Had to mount it directly to the back all. I cut out the carpet that covers the back which helps hide the wires. I am running Polk Audio MOMO 5 1/4" components in the front and back with an extra set of tweeters on the dash. I custom made 5 1/4" adapters for these to fit the factory 5 X 7 holes. Sounds great! I will post pictures when I download them. Also running a Polk Audio MOMO 10" sub in a Qlogic box. The back seat actually wasn't as bad to take out as I was imagining. If you get the screw driver in the right spot, the clip just pops of. It kind of helped that the drivers side wasn't clipped from the factory. Hope you guys are good and thanks again! Aloha!!!
