Wiring tips
Old Jan 30, 2007 | 07:23 PM
ChadS98GT's Avatar
Wiring tips
Alright guys I am going to get ready to run my wiring for my amp just wondering if anyone has any helpful tips before I get started. I am planning on going down the drivers side somewhere.
Any info would be great. :santa:
Old Jan 30, 2007 | 07:29 PM
jmt0645's Avatar
the only tip I know to give you is to run the power and RCA's on opposite sides of the truck to prevent interference.
Old Jan 30, 2007 | 07:30 PM
ChadS98GT's Avatar
good tip.. I would of likely ran them on the same side lol.
Anything else
Old Jan 30, 2007 | 07:45 PM
Impact9's Avatar
Anything else
yea, get a good ground. Sand away the paint down to bare metal where to ground the amp to help eliminate noise.
Old Jan 30, 2007 | 07:59 PM
ieee_raider's Avatar
x10
Old Jan 30, 2007 | 08:03 PM
ChadS98GT's Avatar
well I am mounting it under the rear scab seat. the double bench. any good points off the top of your head or am I going to have to make one?
Old Jan 30, 2007 | 08:22 PM
jmt0645's Avatar
I curently have mine grounded to the bolt that holds the jack down.
It's just under my cap
Old Jan 30, 2007 | 09:22 PM
ChadS98GT's Avatar
ah ok cool. I will probably do something similar.
Old Jan 30, 2007 | 09:55 PM
Bartak1's Avatar
What kind of tips? Anything really?
Cover every inch of the power wire outside the vehicle in looming, if you want to be extra carefully cover the whole thing. Run it down the side under the sill plate, along with your turn on wire.
Solder and heatshrink the turn on wire where you splice it onto a wire if you can, or at least crimp and tape it.
RCA's down the opposite side of vehicle, try to keep them away from bigger power wires.
If you crimp on a terminal, it also helps to solder it some too. Makes a nice strong connection. Use those rubber boot type things over the crimped part of the terminal too-little extra protection, plus it makes it look a lot nicer.
A good ground is VERY important. Make sure it is a good solid ground-dont attach it to some little bracket that spot welded to the body or anything. Directley to the floor is your best place. Make sure its clean and nice bare metal. Spend some time on it, get all paint off, sand it down some, get it nice and shiny.
Cut your wires to the proper lenght, extra lengths of wire laying around look bad. Keep everything nice and tidy.
A few basic things to start you off...
Old Jan 30, 2007 | 11:15 PM
ChadS98GT's Avatar
haha thanks..
how bout getting through the firewall for the power wire? I havn't looked but hopefully there is room and a nice easy spot.
Old Jan 31, 2007 | 09:40 PM
jmt0645's Avatar
There is actually 2 spots to go through the firewall without drilling.
1) big grommet just behind the batterie, runs right behind fuse center.
This is where mine is run through at.
2) Med grommet on drivers side just behind FMU in plain site. This would be the easiest to get to, but be sure to think out your wire run as this one enters just above the brake peddle. Also be sure to hide the wiring in the engine compartment so it looks pro.
and another thing, Your best bet with the RCA's is to go directly down the center of the truck on the trans tunnel as there is hardly any factory harness there. And the 1 harness that is there you will cross at a 90*angle which won't cause intereference.
Old Feb 3, 2007 | 06:37 PM
SSpiro's Avatar
Where is this trans tunnel? Same for SCrew?
Old Feb 3, 2007 | 09:07 PM
jmt0645's Avatar
Trans tunnel = big hump in center of truck, same on all cabs
Old Feb 3, 2007 | 09:21 PM
ChadS98GT's Avatar
right.....but how do you get to it?? tear the carpet up?
Old Feb 3, 2007 | 09:27 PM
jmt0645's Avatar
All I had to do was remove the center console, there is enough slack in our carpeting to just run the "wires" under it without much of a problem.
