Checking Amp Gains
Old Jan 30, 2007 | 08:40 AM
naiku's Avatar
Checking Amp Gains
I need some help in calculating my gains, where my amp will be positioned its not going to be easy to adjust them, so I want to get them right first time.
I have a 4 channel amp that puts out 50RMS @ 4 ohms / 4 x 75 @ 2 ohms / 2 x 150 Bridged at 4 ohms, I calculated the following:
Front 2 channels will be hooked up at 2 ohms so sqrt (75 *2) = 12.25 volts
Rear 2 channels will be bridged at 4 ohms so sqrt (150 * 4) = 24.49 volts
Can someone confirm that these are correct? also what would be an good test tone to play for the front speakers and for the sub?
Thanks.
Old Jan 30, 2007 | 12:46 PM
dconder's Avatar
Thanks.
Good calculator here:
http://www.subwoofertools.com/forum/setgain.asp
Maybe 1,000hz for the fronts and 50-60 for the sub.
Old Jan 30, 2007 | 06:09 PM
Bartak1's Avatar
Yes, your calculations are correct.
Like D said, use a 1k Hz tone for the front, and something like a 50 Hz for the sub...
