Fuse Size Recommendation
Saw the other post about popping fuses and I was wondering what size main fuse from the battery would be recommended for this amp http://www.rockfordfosgate.com/produ...s=discontinued
I'm thinking about using a circuit breaker typeon my 4AWG so I wont have to worry about buying fuses so let me know what size you think I should use and if anyone has had any luck with the breaker type fuses?I have 2 MTX DVC 5512 12" subs also that's been wired at 4 Ohms.
Just remember, your fuse is your weak link. That is your protection. A little lower is always better than higher. I run only a 60 amp fuse with my 3 amps and over 1400 watts and have not blown one. I would not go over 100 for sure and with only that amp, might even try a little lower first. If it blows, you can always go a bit higher but, if you start to high.....
Yea that did sound a little overboard,I don't want to over heatthe wires and cause some serious trouble down the line.I'm also using a 4GA wire.
Originally Posted by TXhustla
Would 120A be good in 1/0 gauge?
Originally Posted by ieee_raider
You should size it for the amp, not for the gauge of wire... unless the wire you're using is too small for your amp. Basically size it for the weakest link.
150 Amp x 12 Volts= 1800 watts
You could have atleast three 500 watts amps on that.
TxHustla I wouldn't put a bigger fuse in, if the system will work off the smaller fuse. It's more of a risk to run a bigger fuse. The only way I'd put a bigger fuse in is if your amps are blowing the fuse from to much current draw. I don't see that happening to often.
