Older Zapco
Old Dec 20, 2006 | 08:04 PM
jdoggfx4's Avatar
Older Zapco
I have a Zapco AG 750 I have used it for a couple of years with no problem. But now that I have installed it in my truck whenever the bass hits harder then normal it makes the fuse blow...
Any Ideas..
Old Dec 20, 2006 | 10:12 PM
Bartak1's Avatar
Dont just have to small of fuses, do you?
Old Dec 21, 2006 | 12:36 AM
scsmitty78's Avatar
According to the zapco site the amp has 3 25a fuses. Are they blowing or is it your inline fuse?
Old Dec 21, 2006 | 09:28 AM
jdoggfx4's Avatar
No I'm not blowing the in-line I'm blowing the 3 25a all at once. It plays fine till it gets a long or harder then normal bass drop. I used to power 2 12's with it now I'm only powering one 10. I really lost as to what the problem could be.
Old Dec 21, 2006 | 09:33 AM
dconder's Avatar
I would try and check your voltage at the amp. If you have a DMM, check it with the engine running with it cranked up pretty good and see if you are getting a drop. Its not a solution but, it might tell you that it is in the amp or in the wiring.
Old Dec 21, 2006 | 10:02 AM
Bartak1's Avatar
Sub wired for too low of a load?
Old Dec 21, 2006 | 10:13 AM
dconder's Avatar
It is only rated for a 4 ohm mono load. Could be a contender.
Old Dec 21, 2006 | 10:55 AM
jdoggfx4's Avatar
I have it bridged, Do you think un-bridging ti will help?
I also have the gain turned WAY LOW to help.
Also I have a one fared(sp) cap in-line before the amp to help with power.
Old Dec 21, 2006 | 11:14 AM
dconder's Avatar
What is the sub and how is it wired?
Old Dec 21, 2006 | 11:30 AM
brypink2's Avatar
It's gotta be the final impedance. We need to know the ohm rating of the sub and how it is wired (parallel or series).
Old Dec 21, 2006 | 11:49 AM
jdoggfx4's Avatar
It is a audiobahn DVC 10 it is wired in parallel I belive it is 2 ohm
Old Dec 21, 2006 | 12:33 PM
dconder's Avatar
It will either be a dual 4 or dual 2 ohm sub. Either way, if you are running it in parallel, this could be your problem. Dual 4 run in parallel will be 2 ohm. Dual 2 will be 1 ohm. Your amp is only designed to run a 4 ohm bridged load. If it is dual 4, wire it in series to present an 8 ohm load. It will cut your power in half. If it is dual 2, wire it in series for 4 ohm load and full bridged power.
