Wiring
Old Dec 6, 2006 | 11:09 PM
C-Expo's Avatar
Question Wiring
ok guys its time to learn how to wire.
im goin to be getting 2 Rockford Fosgate Punch Stage 3 P310D4
Sensitivity: 85 dB
Recommended RMS Power: 400W
Peak Power Handling: 800W
Impedance: dual 4 ohms
I was thinking about the Rockford Fosgate Punch P6001bd amp
300 W x 1 @ 4 Ohms RMS
600 W x 1 @ 2 Ohms RMS
Total power 600 Watts
im not exactly sure it will be powerful enough for the 2 subs
if it is how should i wire them
it its not could u suggest and amp and how to wire it.
thanks i appreciate any help
Old Dec 7, 2006 | 07:27 AM
dconder's Avatar
With dual 4 ohm voice coil subs, your wiring options are going to be 1 or 4. The amp will not do 1 ohm and not do its max power at 4 ohm. I would maybe think about getting dual 2 ohm subs. That way, you can wire them to a 2 ohm final load and put 300 watts per sub. Either that or look at another amp.
Old Dec 7, 2006 | 05:52 PM
C-Expo's Avatar
ok so then what amp would you recommend for that set up and how would you wire it
and plus what is the difference between dual 2ohm and dual 4 ohm subs
rockford also makes the same sub in 2 ohm. would there be any difference in sound quality
Old Dec 8, 2006 | 08:36 AM
dconder's Avatar
I would just switch to the dual 2 ohm subs. There is no difference in quality of a dual 2 or 4 ohm sub or a single voice coil sub. It is all about wiring flexability and getting the load right for your amp.
