Amp question????
Old Sep 8, 2006 | 06:50 PM
TXhustla's Avatar
Amp question????
In general what should be looked for in a amp. I dont mean brand, watts, impedence. What makes it work correctly I have seen carbon fiber, keflar, bulletproof, gold, black etc. amps are these an others efficent or extras?
Old Sep 8, 2006 | 11:18 PM
brypink2's Avatar
An amp that matches your speakers/sub and fits in your budget is a start.
Other than that...it depends on a component amp or sub amp. There's a few things to look at, but nothing that is drastically gonna make amp A sound that much different than amp B.
Old Sep 9, 2006 | 11:11 AM
TXhustla's Avatar
So a sub amp that has titaniaum alloy or something like that does not affect its production(clipping, overheating etc.)..........
Old Sep 9, 2006 | 11:32 AM
dconder's Avatar
The old saying rings true, you get what you pay for. All the fancy names and outrageous ratings really mean nothing. Stick to good solid brand names and like Bryan said, what fits your budget and you should be fine.
Old Sep 9, 2006 | 02:51 PM
TXhustla's Avatar
Say the budget was fine and was comparing different amps that where all the same price, "solid brand names", impedence was good basicly all same quality. But were made with different materials carbon fiber, alloy, bulletbroof etc. how would this make a difference?????????
Old Sep 9, 2006 | 03:37 PM
brypink2's Avatar
Gimmicks IMHO. Can you give specifics of these amps?
Old Sep 9, 2006 | 03:50 PM
dconder's Avatar
I agree. Nothing that is going to matter to how they sound which is what matters most.
Old Sep 9, 2006 | 08:29 PM
TXhustla's Avatar
Im just speaking in general but mono blocks in particular. Punch, JL, Soundstream, Zapco, Lanzar etc. Its like every amp I see has different makings. Sound is not the only thing that matters. What about overheating, clipping how long it can produce whatever watts it says............
Old Sep 9, 2006 | 09:43 PM
dconder's Avatar
You are getting wrapped up in specs and features that will really not make sound quality difference. Clipping is directly related to sound quality. Any good brand name amp installed properly, should not have any concerns about overheating or clipping. Again, once installed properly, all quality amps should produce good results. Other than power differences, most people are not even going to be able to tell a difference in mono amps with similar specs.
Old Sep 11, 2006 | 07:04 PM
TXhustla's Avatar
Does the same apply for subs? If a busted coil was on a good amp would it overheat???
Old Sep 17, 2006 | 06:54 PM
TXhustla's Avatar
I have two 4ohm SVC that read 2.3 on amp. If I were to get a third an use a 1ohm stable amp would it read 1.3??
