Best way to wire these subs?
I finally bought a amp for my subs. Now I need to know what is the best way to wire them up.
Amp - http://www.sonicelectronix.com/item_360.html
Subs - http://www.onlinecarstereo.com/CarAu...roductID=16821
This is how i am thinking of wiring them. Option 1
http://www.the12volt.com/caraudio/wo...igurations.asp
You have two 4ohm dual voice coil subs, so the best wiring options you have are wiring them at a total of 1ohm load or 4ohm load.The subs have are rated at 450 watts rms. Your amp manufactorer claims to put out 1500 watts rms @ 1ohm and 500 watts rms @ 4 ohms.
Here is a site that has a wireguide for your application just put in the info that applies...
http://www.cardomain.com/shop/woofer...dvc&x=140&y=14
I would wire them in parallel since you have 4 ohm dual voice coils and a 1 ohm stable amp. You will get more power from the amp. Although from years of experience with audio systems I have found you pay for what you get and for true watts from an amp, it cost about 1 dollar per true watt. Most off brand name amps don't push what they say they do.
thanks for all your replys. i got them hooked up today, and they sound awsome. they are alot better then my previous subs and amp, 2 10" explodes and a pioneer 760 watt amp. lol.
