Remote gain problem
Old Aug 7, 2006 | 10:16 PM
TXhustla's Avatar
Remote gain problem
At first I thought it was since I have it ran under carpet along side with RCAs (not to mention what else is under there). But I took it from up underneth and it still wont let me turn up or down. Suggestions............?
Old Aug 7, 2006 | 11:19 PM
Bartak1's Avatar
What kind of amp is it?
Old Aug 8, 2006 | 10:53 AM
Muddyape's Avatar
Is it the JL Audio RBC-1? If so, I ran mine along with the RCA etc. no probs at all. All I could suggest is things i'm sure youve tried....recheck your connections, if **** is detachable for installation make sure it isnt strip (turning the switch it self and not just spinning) if an old switch or **** spray some contact cleaner. If not think about getting a new gain control from your dealer or the manufacturer.
Old Aug 8, 2006 | 09:05 PM
TXhustla's Avatar
Coustic 800D could I just get a different type of ****?
Old Aug 8, 2006 | 10:22 PM
Muddyape's Avatar
I guess it would depend on how it disassembles...if your turning the **** and its not ativating the switch it may be a simple fix. My set up utilizes a phone jack to disconnect the switch/**** from the wire itself. Try to break it down (if you can) clean it, check for obvious damage and try again. If not I would contact coustic and ask for a replacement.
Old Aug 9, 2006 | 02:56 PM
TXhustla's Avatar
Should it read a certain number with a volt meter?
Old Aug 12, 2006 | 12:20 PM
TXhustla's Avatar
