charging capacitor help
i just installed my amp and capacitor but dont have the charging resistor. i understand if i hook it up without charging it ill get a spark but once i get over that will it still charge and work on its own or do i really need to charge it.
thanks
dennis
thanks
dennis
thanks
dennis
thanks
dennis
Originally Posted by styxnpicks
the best way to charge it is to dissconect it and drop in in the trash
can be charged with a 12v light bulb on pig tails in a pinch... on your battery, remove main amp feed, disconnect amps or pull fuses.. nothing wired but cap.. put a light bulb between bat pos. and amp feed, light will come on.. when light goes out, cap is charged.....
caps lower your voltage and add more load to your alternator. throw it away
When discharged they are a load but so is your battery. Caps do not lower your overall voltage unless your charging system sucks to begin with.
Charging them is not needed.
