Help... Amp not working....
Old Jul 9, 2006 | 04:37 PM
ufscrew's Avatar
my 4-channel amp is not powering the rear speakers correctly and it seems to be getting really hot. it almost sounds as though the rear speakers are blown. i tried to swap rca's and it did no good. the front sounds fine. is there anyway to test an amp?
Old Jul 9, 2006 | 04:58 PM
Bartak1's Avatar
Maybe a short in the speaker wires?? You could stick a DMM on the amps outputs and see if you get a reading (on the AC volt setting).
How are are your gains?
Old Jul 9, 2006 | 05:01 PM
ufscrew's Avatar
gains are set at about half. what reading should i get at the outputs?
Old Jul 9, 2006 | 05:16 PM
ufscrew's Avatar
i just removed all speaker wire and tested each speaker with each rca. it apears that i have an rca problem! here goes nothing....
Old Jul 9, 2006 | 06:28 PM
ufscrew's Avatar
after all the checking the head unit is faulty. crutchfield is shipping a new one!
Old Jul 9, 2006 | 07:54 PM
Bartak1's Avatar
Thats good you got the problem figured out. So is the HU warrantied?
