Eclipse Amp Install
Eclipse Amp Install
I finished installing my Amps, Sounds good, but I think the rewired factory sub could would sound better with a better quality sub in it...but not bad by any means....
Eclipse EA2000 2CH bridged to 1CH (175W) feeding rewired factory sub
Eclipse EA4000 4CH (4x75w) feeding 4 Infinity 6812CS 2ways
(2) Monster 1.0 Farad Caps
Lightning Cap Mount Dist, Block
4ga main w/100AMP ANL
8ga feeds
couple pics, more in gallery under Eclipse
8ga feeds
I see you have your amps mounted directly to the cab. Give you any problems? Thinking I might relocate my security box again so I can get my amp down a little further. I just didn't really want to mount it right on the wall though without something between it.
Don't mount you BCM up where I moved mind to... I had a h$ll of a time getting to seat to catch... I may have to move it down some, if I can.... It pinched tight on the seat now...
