protect mode
Old Mar 22, 2006 | 07:25 PM
phattbaztard03's Avatar
Question protect mode
my amp, Clarion APA250, keeps switching to protect mode when sub, dvc Hifonics Atlas, hits hard. I am not sure whether its because i only used 8 gauge wire instead of my usual 4 guage, or if it is because of something else.
my old amp, Boss 250 runnig the same sub from the same power source has no problem aside from gettling a little on the warm side.
please help man, I have installed about 2 dozen amps and this is the first time i have taken an amp from the box and have this kinda prob!
Old Mar 22, 2006 | 09:07 PM
gotta be someone who knows something. by the way the gain is all the way down and bass boost at +6 and cuts off. if the bass boost is off and gain down all the way then cuts off
Old Mar 23, 2006 | 02:21 PM
1 bad bolt's Avatar
it could be from not having 4 gauge wire, if it is supposed to take 4 gauge in, " not supplying enough voltage " when you hit real hard bass notes or possible of over working the amp,does the amp get real hot when beating on it ? how high is the gain set, also possible of having a internal short
Old Mar 23, 2006 | 02:23 PM
1 bad bolt's Avatar
try getting a volt meter and see how low the voltage goes b4 shutting down into protection mode, i will drop normally but if it goes really low good chance of the 8 gauge not being sufficent enough
Old Mar 23, 2006 | 02:41 PM
dconder's Avatar
I think you are on the right track. Check that voltage drop.
Old Mar 23, 2006 | 05:20 PM
what abouth the sub being wired at 2 ohm, how do i wire it to 4 ohm (sub is dvc)
Old Mar 23, 2006 | 05:28 PM
dconder's Avatar
It depends. If it is a dual 4 ohm voice coil sub, you can only wire it to 2 or 8 ohms. If it is dual 2 ohm voice coils, you can wire it to 1 or 4 ohm.
