Would this amp mount location be stable....
I am thinking of mounting my 4 channel amp onto the back plastic wall panel of the cab... I want to keep it off the floor and I thought that if I could mount it to the back wall it would be good. Would the back panel be able to hold it up and stay clipped into place? THanks
Matt
Matt
What I did on my ranger is I bent a piece of 3/8 thick aluminum to an L shape the back of it was the size of the amp and the bottom sat on the floor over the holes for the jump seat. I drilled the bottom to line up with the holes and used the jumpseat bolts to hold it in place. The back I drilled and taped for bolts to hold the amp in place. It sat off the back wall about 1/4 of an inch and never rattled against the wall.
Matt
Matt
