Triple Battery Terminal
Old Apr 17, 2005 | 08:11 PM
LeanNCut's Avatar
Is there such a thing as a 3-connection or 4-connection battery terminal? I run all Streetwires wiring and accessories but the max from Streetwires is a dual-connection terminal. The factory wires and the 0 gauge amp wire take up both hot connections leaving no space for the HID lights.
I'm sure someone out there has a lot more accessories and lights than I do. Maybe they found a solution.
Old Apr 17, 2005 | 08:58 PM
arrbilly's Avatar
any high-end install place should be able to help you out...
Old Apr 17, 2005 | 10:20 PM
LeanNCut's Avatar
I went to CarToys and they weren't sure what to do LOL. They did offer to "upgrade" my sub box to fiberglass for a mere 800 bucks though.
Old Apr 17, 2005 | 10:54 PM
Bartak1's Avatar
How about running a short piece of huge power wire from the terminal to a distribution block under the hood that has like 4 or so outputs.
Something wtih like a 1/0 gauge input, and a bunch of 10 or 8 gauge outputs.
Might be something to try.
Old Apr 17, 2005 | 11:19 PM
LeanNCut's Avatar
That's a great idea Bartak, unfortunately as far as I know Streetwires doesn't have any such power distribution blocks. The blocks always seem to be a 0/1 gauge in, 4-8 gauge out type of setup.
Old Apr 18, 2005 | 11:46 AM
joebronco94's Avatar
try stinger they have a big selection
Old Apr 18, 2005 | 03:28 PM
Bartak1's Avatar
Well I looked on Streetwires website and see they have them with 1/0 or 4 gauge inputs, and 8 gauge outputs. Im betting you could find those 'sleeve' type things that go in like fuse holders so you can hook up 10 or 8 gauge wire. They go where the wire hooks up, takes up the extra space for the 10 gauge wire. get a couple of those and put them in the distr. block so you can stick 10 gauge in there.
And Id think 10 gauge would be a pretty good size for lots of lights and higher current stuff.
Id think it would work
