Amp problem
Old Nov 20, 2004 | 08:17 AM
adboyo's Avatar
Amp problem
there is something really wierd that is happening to my amp, i hook it up wo the umps and power and it has power and all that, but every time i turn on the subs and stero i blow the fuse on the amp. Does anyone knw what the matter is? did i hook it up wrong?
thanks
-adam
Old Nov 20, 2004 | 04:07 PM
brown0617's Avatar
Are you blowing the inline fuse for the amp?
I'd check all of your connections, make sure you've got a really good ground.
Old Nov 23, 2004 | 01:43 PM
frostby's Avatar
Start by removing the speakers, and rca's. Keep It Simple. Does the power hold now?
Old Nov 23, 2004 | 04:20 PM
adboyo's Avatar
the amp is holding power, its every time me and my friend turn the subs on it blows the fuse on the outside of the amp. i was told by a tech represntative from BOSS (amp company) that the wire job or the subs could be bad. is that true??
Old Nov 23, 2004 | 05:54 PM
Dupuis's Avatar
Check to make sure your sub amp power and ground wires are not touching any where. Also check your connctions on the subs them selfs. May have a + and - touching somewhere.
