tell me about this setup
Old Feb 10, 2004 | 06:32 PM
Three B's Avatar
ok i already have...
alpine face unit cda-7995
mb quart component speakers rsc-213
im thinkin...
a memphis amp(not sure of which 1 yet)
2 10 jl audiow3v2 subs
a custom box
do yall think that will sound good. keep in mind i have a 2004 extended cab f-150.
im talkin to a guy from hyper audio as of now and hes giving me really good prices for the audio
for the subs 179 each
neways if yall have had ne experience with memphis audio or the jl audio w3v2 or hyper audio as a dealer plz post ne pics you can and reply as much as possible!
Old Feb 10, 2004 | 07:39 PM
Deus's Avatar
Check out the Phoenix Gold Ti10 subs. Awesome subs for ~$150/pr.
Old Feb 29, 2004 | 05:56 PM
twcpres's Avatar
I can give you some good info but what is your budget for this system. JL makes an awesome sub but you need some good clean power to run them and for the subs you are going with I would suggest getting a JL Audio 500/1 it is definitely worth the $$$ I had this in my Sporttrac running 3 8w6's the bass was clean and low.
Specifications:
Rated Power:
500 W RMS @ 1.5 ohm-4 ohm
(11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio*:
>95dB below rated power
Frequency Response:
5 Hz-500 Hz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm/50 Hz
Input Range:
switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions:
13.4"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology:
(1 pair of inputs)
On-board Crossover:
fully-variable (40-200 Hz),
selectable-slope LP (12 or 24 dB per octave)
Preamp Output:
2-channel (independent active filter, parallel with amp filter or full-range)
Bass EQ:
parametric with variable boost up to 15dB and Remote Bass Control (optional)
Infrasonic Filter:
fully-variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On:
permits operation without remote lead
Dual mono speaker output connections:
accept up to 8ga. wire
+12V and Ground connections:
accept up to 4ga. Wire
Old Mar 11, 2004 | 09:58 PM
MEAT BAG's Avatar
try listening to some Image Dynamic IDQ subs. they can be bought for around $110 online for the 10" dont require that much power and sound awsome. Another bonus is that they are only about 6" deep from what i remember.
Old Mar 11, 2004 | 10:39 PM
SykoX's Avatar
Three B, I will limit this to your question about the amp as I have a tiny bit of experience with the Memphis equipment. It is by far some of the best out there right now for the money. Excellent warranty and a great group of guys to boot. I am running dual MC84 (Memphis Single Voice Coil 8") subs off of a MC250D (Memphis 250x1)amp in my 04 Scab. It sounds excellent, wonderful reproduction, loud tight bass, just really nice all the way around. Memphis makes the MClass amp in 250, 500, 1000, and 1500. Right now they are quite affordable but I would expect that to change real soon as they start getting national attention. Now don't get me wrong here, there are a ton of great amps out there but for my money I'll stick with Memphis.
plus it's cool that they are from my hometown!
Old Mar 13, 2004 | 09:09 AM
cgorris's Avatar
I have used Memphis and knew about them about 5-6 years ago when they first started to come on the scene. They have excellent support and stand behind thier product. I never had any problems with my Memphis amp. In fact, the guy that has it now is still getting great output from it without ever any problems (6 yrs old).
Of course the JL and Quart speakers are also a great choice.
