Amp Install
Old Dec 15, 2003 | 11:36 PM
wings_023's Avatar
Amp Install
Hi all
My question is what is the best way to install a amp. Or more specific, what is the best way to get the power wire to the amp from the battery (amp placed under the passanger side of the the rear seat of a '03 Supercab), through the firewall?
And then what is the best wiring route for the amp remote wire and RCA wires from the head unit?
Just looking for the "least invasive" procedure. Don't want to tear the interior up too much.
Thanks for the help in advance!
Adam
Old Dec 16, 2003 | 09:45 PM
Bartak1's Avatar
The sill plates(think thats what they are called) just pop off, and its a really good place to run your wires.
There are some grommets on the drivers side under the dash that you can run the wire through, or on the passengers side, if you look under the truck, right by the rocker pannel, towards the front of the door on the bottom of the truck(confused yet) there is a little round grommet. If you pop off the sill plate on the pass. side you will see the grommet also on the inside. I am going to run my wire here i think. It is a good place. Just run the power wire from the battery, on top of the inner fenderwell, and under the truck for liek 10 inches to the grommet.
Here is a site that will help with your amp install. If you csroll down half way and look to the rifght there are arcticles on installing them. site-> Click Here
Good luck!
