Amp Placement
Amp Placement
Does anyone know what type and size tool I need to take the driver's seat out? I take it that all I need to do is take out the 4 star or allen screws/bolts, and then unclick the wire harness, if it unclips? Also what is the best way to attach the amp under the driver's seat. I am looking for a way so I don't have to attach it by screwing or bolting thru the cab floor. Is there really any other way?
Re: Amp Placement
would that actually work? Would the heat from the amp make the glue from the velcro run or get all goey on the amp itself?
Seat bolts will require a Torx bit, T55 size.
As far as the amp mounting, this is from a posting I did in answer to a question from you not too long ago...
Originally posted by B-Man
...<Snip>As far as mounting the amp, I'd get some aluminum from Home Depot and make a bracket that reaches from one seat rail to the other. Bend it to shape, screw it to the seat rail and mount your amp to that. Cheap, easy to work with, and no holes in your floorpan...<Snip>
