EVAP Sytem Switch Valve Stuck Open
Old May 19, 2025 | 02:02 PM
MELAGER1's Avatar
I am getting a EVAP System Switching Valve Performance / Stuck OPen P2450 Code on my 2021 F150. Have not found any noted info on this issues, anyone Faced this yet, Only 34000 miles on her.
Old May 19, 2025 | 03:30 PM
That should be covered under the 7/70 emissions warranty. Check with your dealer.
Old May 19, 2025 | 04:44 PM
projectSHO89's Avatar
glc is correct, it's covered. Shouldn't cost you anything except some time.
The problem is likely the purge valve, a pretty common issue. Just google your fault code and Fords.
