2017 5.0 will not even turn over
Battery is good. Installed a new starter, changed starter relay checked all ground connections.
Put the key in the ignition all lights come on as they should try to start it and get a click nothing more? if someone has any input, it would be appreciated.
The Ignition switch On, powers up the Computer and the Dash.
When put into "start position', the switch closes an electrical path through the Tran position switch in Neutral and or Park.
This powers the Start Relay as likely the clunk you hear.
This relay closes the 'heavy' power circuit from Battery to the Starter. That may be the Clunk as well.
The Starter throws out a small gear to engage the Flywheel and turn the engine over.
Your failure is just after the part of the action that makes the clunk sound.
Think it through from that point.
Good luck.
Good luck.
