Front turn signal problem
Old Feb 20, 2023 | 08:33 PM
Squeaks's Avatar
I’m new to the forum. I have a 2015 F150 xlt and my front turn signals will not work when headlights are on. Turn signals in mirrors and rear signals work fine. When I hit the turn signal switch inside the can it hyper flashes. No led bulbs factory. I’ve checked and replaced all bulbs and clean the sockets out. I’ve checked what I could find of grounds all seem fine. Any help or suggestions would be greatly appreciated. I can’t get it into the dealer for 2 weeks.
Old Feb 21, 2023 | 01:34 PM
projectSHO89's Avatar
1. Do the signals work normally when the headlights are off?
2. Regarding the factory headlights, are they LED or non-LED. Both versions were available.
3. Parking/running lamps normal or not?
Old Feb 21, 2023 | 05:48 PM
Squeaks's Avatar
signals blink normal when headlights are off. Inside the cab they hyper flash in the cluster.
non led headlights
parking lights and running lights normal
Old Feb 21, 2023 | 06:24 PM
Do the cluster indicators hyper flash when the outside bulbs are flashing normally (while headlights are off)?
Old Feb 21, 2023 | 06:37 PM
Squeaks's Avatar
Yes outside flashes normal while the inside is hyper flashing while headlights are off
Old Mar 4, 2023 | 10:00 AM
Squeaks's Avatar
Anyone have any ideas ?
Old Mar 4, 2023 | 06:15 PM
Have you scanned the BCM for any fault codes?
Old Mar 4, 2023 | 06:22 PM
Squeaks's Avatar
Short circuit on all exterior lights
