Failing compressor coil?
Old Jul 8, 2021 | 08:36 PM
Eric_v's Avatar
A/C stopped working and was blowing the 10a (fuse 44) fuses anytime the coil tried pulling the clutch in. Disconnected harness from coil and fuse held. Being an electrician I thought what the hell, if it's a short I'll bump the current up and try and clear it. Threw a 30a at it and low and behold it held. Put 10a back in and it also held and A/C is working fine again.
So I'm thinking either I blew the short clear or the wire is worn through and I cleared it moving the harness and wires around.
Thoughts?
Old Jul 8, 2021 | 09:41 PM
Roadie's Avatar
So you are an electrician and you decide to replace a blown 10amp fuse with a 30 amp!? I think I would have checked resistance to ground in the clutch and the wiring harness, and resistance of the coil in the clutch.
Old Jul 8, 2021 | 11:09 PM
Eric_v's Avatar
So your a senior member and have nothing to add other than assuming the steps I supposedly didn't take. Sorry I didn't go into great detail, thought I'd keep it short. Coil read 2.4 ohms, all else was clear and voltage to connector was 11.8.
Old Jul 9, 2021 | 08:09 AM
projectSHO89's Avatar
It helps if you EXPLICITLY identify what you're working on....
Probably....
Old Jul 10, 2021 | 08:43 AM
Eric_v's Avatar
Sorry about that. 2015 screw 3.5 eco 4x4.
Was a little premature thinking it was working. Clutch only held for the one cycle then was blowing fuse again. Anyway, got back in it and moved all the wires around like I was riding on a backroad and it never popped, this was with connector disconnected. Checked reading at the relay and noticed 3.8v on pin 3 which looking at the wiring diagram is hot at all times from PCM. Seems like an odd voltage though. I can't remember if I checked it when the PCM called for clutch active.
Old Jul 10, 2021 | 10:07 AM
I'd have to see the schematic to comment further (my service library only goes up to the 2013 model year for the F150).
