No shift after 4000 RPM
Old Aug 11, 2020 | 02:32 PM
vadim4120's Avatar
Hi there. New member here. I have a 2017 F150 5.0. Truck shifts and drives normally, but when I floor it, it gets to about 4000 RPM and does not want to shift. Ran diagnostic and it gave me a P0339. Reset all codes and it still has same issue without the code coming back. Don't think it's the crankshaft position sensor or the fuel pump because the truck runs fine at lower rpms and higher speeds. Any thoughts? Thanks in advance.
Old Aug 13, 2020 | 06:48 PM
Bluegrass's Avatar
Yes, your second guessing the computer code.
339 says >>intermittent<<. Crank sensor circuit.
Don't dismiss codes. They never fail to give a hint. Re setting to clear a code does not clear any trouble.
What does ya think? Maybe vibration sensitive?
Better at least check the plug-up seating.
Good luck.
Old Aug 21, 2020 | 08:09 PM
vadim4120's Avatar
Good luck.
I replaced it, reset codes, took it for a spin and it works great now. Thanks for your help
