2018 F-150 Grinding in 2WD
Old May 17, 2020 | 07:16 PM
homebrewer's Avatar
Hey everyone,
My 2018 F-150 SuperCab has given me zero issues since the day I picked it up.
However, yesterday, while driving home from work, I noticed a grinding in the front end (which I can feel through the gas pedal) when I accelerate to about 35-40 km/h, in 2WD on flat-ish ground, and is damn-near constant when going uphill, even a slight incline any speed above 50km/h. It only stops when I take my foot off the gas.
I decided to try 4WD on the way to work to see if I still have the issue, but I didn't hear anything, as far as I noticed. I switched it back to 2WD for the drive home this afternoon and was grinding at about 40km/h again.
I'm just wondering if anyone has had this issue before and what could be done to alleviate it.
Thanks in advance!
-Mike
Old May 18, 2020 | 12:17 AM
Your IWE's are not fully disengaging, you are losing vacuum somewhere.
Old May 18, 2020 | 11:41 AM
I'd get an UNLIT propane torch and following the vacuum lines until you hear a change in idle. That will pin point the leak.
Old May 18, 2020 | 01:46 PM
We actually have an article on troubleshooting the IWE system.
https://www.f150online.com/forums/ar...then-some.html
